TRS3243,pdf(3-V TO 5.5-V MULTI
消耗积分:3 | 格式:rar | 大小:443 | 2010-08-31
h1654155957.9921
分享资料个
特性
  • Single-Chip and Single-Supply Interface for IBM™ PC/AT™ Serial Port
  • RS-232 Bus-Pin ESD Protection Exceeds ±15 kV Using Human-Body Model (HBM)
  • Meets or Exceeds the Requirements of TIA/EIA-232-F and ITU v.28 Standards
  • Operates With 3-V to 5.5-V VCC Supply
  • Three Drivers and Five Receivers
  • Low Standby Current . . . 1 mA Typical
  • External Capacitors . . . 4 × 0.1 mF
  • Accepts 5-V Logic Input With 3.3-V Supply
  • Always-Active Noninverting Receiver Output (ROUT2B)
  • Operating Speed
    • TRS3243C, TRS3243I . . . 250 Kbit/s
    • TRS3243FC, TRS3243FI . . . 1000 Kbit/s
  • Operating Temperature
    • TRS3243C, TRS3243FC . . . 0°C to 70°C
    • TRS3243I, TRS3243FI . . . -40°C to 85°C
  • Serial-Mouse Driveability
  • Auto-Powerdown Feature to Disable Driver Outputs When No Valid RS-232 Signal Is Sensed
  • APPLICATIONS
    • Battery-Powered
    • Systems
评论(0)
发评论
下载排行榜
