TRS3232,pdf(3-V to 5.5-V Multi
消耗积分:3 | 格式:rar | 大小:610 | 2010-08-31
申根换
分享资料个
The TRS3232 device consists of two line drivers, two line receivers, and a dual charge-pump circuit with ±15-kV ESD protection pin to pin (serial-port connection pins, including GND). The device meets the requirements of TIA/EIA-232-F and provides the electrical interface between an asynchronous communication controller and the serial-port connector. The charge pump and four small external capacitors allow operation from a single 3-V to 5.5-V supply. The devices operate at data signaling rates up to 250 kbit/s and a maximum of 30-V/µs driver output slew rate.
评论(0)
发评论
下载排行榜
