UA9639,pdf(Dual Differential L
消耗积分:2 | 格式:rar | 大小:214 | 2010-09-04
吴藩
分享资料个
The uA9639C is a dual differential line receiver designed to meet ANSI Standards EIA/TIA-422-B and EIA/TIA-423-B and ITU Recommendations V.10 and V.11. It utilizes Schottky circuitry and has TTL-compatible outputs. The inputs are compatible with either a single-ended or a differential-line system. This device operates from a single 5-V power supply and is supplied in an 8-pin, dual-in-line package.
The uA9639C is characterized for operation from 0°C to 70°C.
评论(0)
发评论
下载排行榜
