AS1119,pdf (144 LED driver wit
消耗积分:5 | 格式:rar | 大小:223 | 2010-09-06
分享资料个
The AS1119 is a compact LED driver for 144 (90) single LEDs. The devices can be programmed via an I²C compatible interface.
The AS1119 offers two blocks driving each 72 LEDs (3 blocks each 30LEDs) with 1/9 (1/6) cycle rate. The required lines to drive all 144 (90 )LEDs are reduced to 18 by using the cross-plexing feature optimizing space on the PCB. Every block driving 72(30) LEDs can be analog dimmed from 1 to 30mA in 1mA steps.
Additionally each of the 144 (90) LEDs can be dimmed individually with 8-bit allowing 256 steps of linear dimming. To reduce CPU usage up to 6 frames can be stored with individual time delays between frames to play small animations automatically.
The AS1119 operates from 2.7V to 5.5V and includes a 320mA charge-pump to drive also white LEDs. The charge-pump operates in 2:3 and 1:2 mode.
The AS1119 features very low shutdown and operational current.
The device is available in a ultrasmall 36-pin WL-CSP.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
