TPA6211A1,pdf(3.1-W Mono Fully
消耗积分:3 | 格式:rar | 大小:1077 | 2010-09-10
分享资料个
The TPA6211A1 is a 3.1-W mono fully-differential amplifierdesigned to drive a speaker with at least 3-Ω impedance while consuming only 20 mm2 total printed-circuit board (PCB) area in most applications. The device operates from 2.5 V to 5.5 V, drawing only 4 mA of quiescent supply current. The TPA6211A1 is available in the space-saving 3-mm × 3-mm QFN (DRB) and the 8-pin MSOP (DGN) PowerPAD packages.
Features like -80 dB supply voltage rejection from 20 Hz to 2 kHz, improved RF rectification immunity, small PCB area, and a fast startup with minimal pop makes the TPA6211A1 ideal for PDA/smart phone applications.
评论(0)
发评论
下载排行榜
