INA219,pdf(Zerø-Drift,
消耗积分:10 | 格式:rar | 大小:887 | 2010-09-24
张伟
分享资料个
The INA219 is a high-side current shunt and power monitor with an I2C interface. The INA219 monitors both shunt drop and supply voltage, with programmable conversion times and filtering. A programmable calibration value, combined with an internal multiplier, enables direct readouts in amperes. An additional multiplying register calculates power in watts. The I2C interface features 16 programmable addresses.
The INA219 is available in two grades: A and B. The B grade version has higher accuracy and higher precision specifications.
The INA219 senses across shunts on buses that can vary from 0V to 26V. The device uses a single +3V to +5.5V supply, drawing a maximum of 1mA of supply current. The INA219 operates from –40°C to +125°C.
评论(1)
发评论
yyjzd0414 2019-04-12
0 回复 举报
多谢分享 收起回复
下载排行榜
全部1条评论
