max6304/max6303 pdf datasheet
消耗积分:3 | 格式:rar | 大小:666 | 2008-10-01
胡秋阳
分享资料个
The MAX6301–MAX6304* low-power microprocessor
(μP) supervisory circuits provide maximum adjustability
for reset and watchdog functions. The reset threshold
can be adjusted to any voltage above 1.22V, using
external resistors. In addition, the reset and watchdog
timeout periods are adjustable using external capacitors.
A watchdog select pin extends the watchdog timeout
period to 500x. The reset function features immunity
to power-supply transients.
These four devices differ only in the structure of their reset
outputs (see the Selector Guide). The MAX6301–MAX6304
are available in the space-saving 8-pin μMAX® package,
as well as 8-pin PDIP and SO packages.
Applications
Medical Equipment Embedded Controllers
Intelligent Instruments Critical μP Monitoring
Portable Equipment Set-Top Boxes
Battery-Powered Computers
Computers/Controllers
评论(0)
发评论
下载排行榜
