DS1867 pdf datasheet (Dual Dig
消耗积分:3 | 格式:rar | 大小:555 | 2008-10-04
分享资料个
The DS1867 has two 256-position potentiometers, with wiper positions each set as 8-bit values and stored on-chip in nonvolatile memory. Communication takes place through a 3-wire serial port interface that drives an internal control logic unit. Multiple DS1867s can be linked or daisy-chained for control by a single processor.
Digital potentiometers improve upon mechanical devices with processor control and programmability, greater reliability and accuracy, and packaging options that facilitate automatic assembly. This digital potentiometer offers extremely low-power use and reliable, accurate performance throughout the industrial temperature range.
The DS1867 can be used to control the incoming signal levels in modems or for level adjustment and control of RF and audio signals in cellular telephones. Digital potentiometers are also used for battery charging and control circuitry, tuning and calibration, offset trimming of operational amplifiers, gain control, and power supply regulation.
  • Nonvolatile version of the DS1267
  • Two 256-position digital potentiometers
  • Wipers digitally set and read through serial port
  • EEPROM maintains settings in the absence of power
  • Resistors can be connected in series for higher total resistance
  • Ultra low-power consumption, quiet, pumpless design
  • Three-wire serial control interface
  • Operating ranges:
    • Single +5V or ±5V supplies
    • -40°C to +85°C
  • 声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容侵权或者其他违规问题,请联系本站处理。 举报投诉
    评论(0)
    发评论
    下载排行榜
