数字温度传感器TMP101与PrPMC800模块的接口应用
消耗积分:5 | 格式:rar | 大小:258 | 2010-11-30
ejlwj
分享资料个
TMP101是TI公司生产的12位低功耗、高精度数字温度传感器,较宽的温度测量范围和较高的分辨率使其可以广泛应用于许多温度测量场合。TMP101可通过串行总线接口方便地与数字系统相连,同时还具有关闭模式和报警输出。文中介绍了TMP101的内部结构和主要特性,并给出了与PrPMC800模块的接口应用。
Abstract:
 TMP101 is a 12-Bit digital temperature sensor produced by TI with low power and high precision. It is popular in sorts of applications for its wide temperature measuring range and high resolution. It can easily connect with digital system though serial bus interface besides it has shutdown mode and alarm output. The in-ner block structure and main characters of the chip are introduced as well as the application in practice.
评论(0)
发评论
下载排行榜
