ADAV4601 pdf datasheet (Audio
消耗积分:5 | 格式:rar | 大小:555 | 2008-10-08
李杰
分享资料个
The ADAV4601 is an enhanced audio processor targeting
advanced TV applications with full support for digital and
analog baseband audio. The audio processor, by default, loads a dedicated TV audio flow that incorporates full matrix switching (any input to any output), automatic volume control that compensates for volume changes during advertisements or when switching channels, dynamic bass, a multiband equalizer, and up to 200 ms of stereo
delay memory for audio-video synchronization. Alternatively, Analog Devices offers an award-winning graphical programming tool (SigmaStudio™) that allows custom flows to be quickly developed and evaluated. This allows the creation of customer-specific audio flows, including use of the Analog
Devices library of third-party algorithms.
The analog I/O integrates Analog Devices proprietary
continuous-time, multibit Σ-Δ architecture to bring a higher
level of performance to ATV systems, required by third-party algorithm providers to meet system branding certification. The analog input is provided by 95 dB dynamic range (DNR) ADCs,
and analog output is provided by 94 dB DNR DACs.
The main speaker outputs can be supplied as a digitally modulated PWM stream to support digital amplifiers. The ADAV4601 includes multichannel digital inputs and outputs. In addition, digital input channels can be routed through integrated sample rate converters (SRC), which are capable of supporting any arbitrary sample rate from 5 kHz to 50 kHz.
评论(0)
发评论
下载排行榜
