目前,数据采集系统对采样率、分辨率和抗干扰能力的要求越来越高。尤其是在典型的多路采集+多路开关+单路A/D转换器的数据采集中,采集速度受到限制。为此,介绍了一种基于现场可编程门阵列(FPGA)的高速多路数据采集系统设计和实现。采用模拟开关级联的方法,有效地达到了160路采集速度。采用该方法设计的采集卡能有效完成多路同步高速数据采集任务,且成功地用于某装置的输出信号检测。
- Abstract:
- In the data acquisition system,the request of the sampling rate, distinguishability and anti-interference ability is higher.Especially,acquisition speed is subjected to restriction in the typical data acquisition the technique for multichannel data acquisition,multichannel switches and single-channel A/D converter.This paper introduces the design and implementation of 160-channel data acquisition system based on FPGA.Adopting the method of simulated switch connection,160channel acquisition is realized effectively.The data acquisition card which adopts this method can accomplish the multipath synchro high speed data acquisition and is used to detect the output signals of some device.
