大容量闪存器件K9KAG08U0M与DSP的接口设计
消耗积分:5 | 格式:rar | 大小:692 | 2010-12-25
分享资料个
大容量闪存器件以其体积小、容量大、易于扩展等优点在存储器领域得到广泛应用,介绍2G字节容量NAND Flash K9KAG08U0M的特点和使用方法,并以某激光惯导计算机板设计为例,重点阐述其与数字信号处理器(DSP)TMS320C6713B的硬件接口和软件设计方法。湖试和海试试验结果表明该接口设计方法可靠性高,可扩展能力强,易于编程,具有较高的实用价值。
Abstract:
 NAND Flash is widely applied in the field of memory with its predominances of little cubage,large capacity and easy extensibility.The characteristics and the using method of K9KAG08U0M are introduced in brief.The hardware interface and software design between NAND Flash and TMS320C6713B are expatiated through a CPU board design for laser gyro strap-down inertial navigation system.The examinations in sea and in lake indicate that the interface circuit design is reliable,enlarged and programmed easily,and the design method is valuable in practicality.
评论(0)
发评论
下载排行榜
