opa690器件手册
消耗积分:0 | 格式:rar | 大小:0.62 MB | 2017-10-17
分享资料个
  The OPA690 represents a major step forward in unity-gain
  stable, voltage-feedback op amps. A new internal
  architecture provides slew rate and full-power bandwidth
  previously found only in wideband, current-feedback op
  amps. A new output stage architecture delivers high
  currents with a minimal headroom requirement. These
  combine to give exceptional single-supply operation.
  Using a single +5V supply, the OPA690 can deliver a 1V
  to 4V output swing with over 150mA drive current and
  150MHz bandwidth. This combination of features makes
  the OPA690 an ideal RGB line driver or single-supply
  Analog-to-Digital Converter (ADC) input driver.
  The low 5.5mA supply current of the OPA690 is precisely
  trimmed at 25°C. This trim, along with low temperature
  drift, gives lower maximum supply current than competing
  products. System power may be reduced further using the
  optional disable control pin. Leaving this disable pin open,
  or holding it HIGH, will operate the OPA690 normally. If
  pulled LOW, the OPA690 supply current drops to less than
  100µA while the output goes to a high-impedance state.
  This feature may be used for power savin
opa690器件手册
评论(0)
发评论
下载排行榜
