ML87V2103 pdf datasheet (Video
消耗积分:3 | 格式:rar | 大小:555 | 2008-10-29
维生素B2
分享资料个
The ML87V2103 comprises a 3.9 Mbit field memory and logic circuits for signal processing and memory control. The device can reduce field-recursive noise and double the conversion speed. There is an automatic noise reduction mode that detects the noise level in the input video data to set the optimum noise reduction. There are two ways to double the conversion speed: progressive conversion that doubles the number of lines by doubling the horizontal direction frequency and flicker-free conversion that doubles both the vertical and horizontal direction frequencies.
评论(0)
发评论
下载排行榜
