pt2262 pdf datasheet (Remote C
消耗积分:10 | 格式:rar | 大小:333 | 2008-11-29
安立路
分享资料个
PT2262 is a remote control encoder paired with PT2272 utilizing CMOS Technology. It
encodes data and address pins into a serial coded waveform suitable for RF or IR
modulation. PT2262 has a maximum of 12 bits of tri-state address pins providing up to
531,441 (or 312) address codes; thereby, drastically reducing any code collision and
unauthorized code scanning possibilities.
! CMOS Technology
! Low Power Consumption
! Very High Noise Immunity
! Up to 12 Tri-State Code Address Pins
! Up to 6 Data Pins
! Wide Range of Operating Voltage: Vcc = 4 ~ 15 Volts
! Single Resistor Oscillator
! Latch or Momentary Output Type
! Available in DIP and SO Package
评论(1)
发评论
2011-05-23
0 回复 举报
支持,找了很久这个资料,对pt2262的原理很感兴趣。谢谢 收起回复
下载排行榜
全部1条评论
