MAX3981 pdf datasheet (3.125Gb
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-16
分享资料个
The MAX3981 quad equalizer provides compensation for transmission medium losses for four "lanes" of digital NRZ data at a data rate of 3.125Gbps in one package. It is tailor-made for 10Gigabit Ethernet applications that require attenuation of noise and jitter that occur in communicating with chassis-to-chassis interconnect. In support of IEEE-802.3ae for the XAUI interface, the MAX3981 adaptively allows XAUI lanes to reach 10m (33ft) with inexpensive twin-axial cable for extended backplane applications.
The equalizer has 100Ω differential CML data inputs and outputs.
The MAX3981 is available in a 44-pin exposed-pad QFN package. The MAX3981 consumes only 700mW at 3.3V or 175mW per channel.
评论(0)
发评论
下载排行榜
