MAX5895 pdf datasheet (500Msps
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-18
小组店小二
分享资料个
The MAX5895 programmable interpolating, modulating,
500Msps, dual digital-to-analog converter (DAC) offers
superior dynamic performance and is optimized for
high-performance, wideband single- and multicarrier
transmit applications. The device integrates a selectable
2x/4x/8x interpolating filter, a digital quadrature modula-
tor, and dual 16-bit high-speed DACs on a single IC. At
30MHz output frequency and 500Msps update rate, the
in-band SFDR is 88dBc while consuming 1.1W. The
device also delivers 71dB ACLR for four-carrier WCDMA
at a 61.44MHz output frequency.
评论(0)
发评论
下载排行榜
