ADS1210 24-Bit ANALOG-TO-DIGIT
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-18
分享资料个
The ADS1210 and ADS1211 are precision, wide
dynamic range, delta-sigma analog-to-digital converters
with 24-bit resolution operating from a single +5V
supply. The differential inputs are ideal for direct
connection to transducers or low level voltage signals.
The delta-sigma architecture is used for wide
dynamic range and to guarantee 22 bits of no missing
code performance. An effective resolution of 23 bits
is achieved through the use of a very low-noise input
amplifier at conversion rates up to 10Hz. Effective
resolutions of 20 bits can be maintained up to a
sample rate of 1kHz through the use of the unique
Turbo modulator mode of operation. The dynamic
range of the converters is further increased by providing
a low-noise programmable gain amplifier with a
gain range of 1 to 16 in binary steps.
评论(0)
发评论
下载排行榜
