开源硬件-PMP4333.4-用于电信以及商用电源的 1kW 三轨隔离式 DC/DC 数字电源 (-8V@.25A) PCB layout 设计
消耗积分:10 | 格式:pdf | 大小:2.19MB | 2021-01-05
分享资料个
This reference design demostrates full-function 1.2KW triple-rail digital power supply solution for telecom application. The input range is 36-60Vin and outputs are two 48V10A(Full bridge) and one 5.5V30A(active clamp). Synchrounous rectifiers are used in the design and the overall efficiency is (...)
评论(0)
发评论
下载排行榜
