ADA2200评估板文档
消耗积分:2 | 格式:pdf | 大小:144.24KB | 2021-05-24
分享资料个
This version (28 Apr 2015 23:00) was approved by Michael Fowler, Susan Li.The Previously approved version (17 Feb 2015 16:11) is available.Diff
ADA2200 EVALUATION BOARD WIKI
There are two evaluation boards available for the ADA2200:
ADA2200-EVALZ
The ADA2200-EVALZ is the simpler of the two evaluation boards. It facilitates signal connections to standard test equipment. The part can be reconfigured with the use of the on-board EEPROM.
Figure 1. ADA2200-EVALZ Evaluation Board
User guide, documentation and purchasing information can be found under
http://www.analog.com/en/evaluation/eval-ada2200/eb.html
ADA2200SDP-EVALZ
The ADA2200SDP-EVALZ adds additional input and output signal conditioning circuitry on-board. It also adds an interface to the SDP board. This allows access to the ADA2200 configuration registers over the SPI port with the use of a PC resident GUI application.
Figure 2. ADA2200SDP-EVALZ Evaluation Board
The ADA2200SDP-EVALZ User guide can be downloaded from this link:
http://www.analog.com/media/en/technical-documentation/user-guides/ADA2200SDP-EVALZ_UG-787.pdf
The ACE software used to configure the ADA2200SDP-EVALZ eval board can be downloaded from this link:
Analysis | Control | Evaluation (ACE) Software
The evaluation board contains a reconstruction filter. To calculate new values for the filter, download the excel spreadsheet.
evb_filter.xlsx
评论(0)
发评论
下载排行榜
