AD9154评估文档
消耗积分:2 | 格式:pdf | 大小:48.06KB | 2021-05-26
分享资料个
This version (08 Jul 2020 23:09) was approved by Arik Landsman.The Previously approved version (03 Mar 2015 21:13) is available.Diff
AD9154 Evaluation Board
The AD9154 evaluation boards…
Documentation and software updates for using High-Speed DAC Evaluation Boards are included in individual, self-extracting update files.
Files included in the AD9154 Update:
Item AD9154-EBZ AD9154-ADRF6720-EBZ AD9154-FMC-EBZ
Quick Start AD9154-ebz AD9154-adrf6720-ebz AD9154-FMC-EBZ ACE
Schematics RevDRevARevA
Bill of MaterialsRevD RevARevA
PCB Gerber Files RevDRevARevA
PCB BRD File RevDRevARevA
PCB Layout PDF RevDRevARevA
Data Pattern Generator
The Data Pattern Generator (DPG) is a bench-top instrument for driving vectors into high-speed digital-to-analog converters. The DPG connects to a USB on a PC and allows a user to download a vector from the PC into the internal memory of the DPG. Once downloaded, the vector can be played out to an attached evaluation board for a specific DAC at full speed. This allows for rapid evaluation of the DAC with both generic and custom-generated test data.
For more information on the DPG line of pattern generators and software:
评论(0)
发评论
下载排行榜
