AD9152评估文档
消耗积分:2 | 格式:pdf | 大小:45.99KB | 2021-05-12
吴藩
分享资料个
This version (06 May 2015 05:22) was approved by Patrick Xuan.
AD9152 Evaluation Board
The AD9152 evaluation boards…
Documentation and software updates for using High-Speed DAC Evaluation Boards are included in individual, self-extracting update files.
Files included in the AD9152 Update:
Item AD9152-EBZ AD9152-ADRF6720-EBZ AD9152-FMC-EBZ
Quick Start AD9152-ebz AD9152-adrf6720-ebz AD9152-fmc-ebz
Schematics RevBRevBRevA
Bill of MaterialsRevB RevBRevA
PCB Gerber Files RevBRevBRevA
PCB BRD File RevBRevBRevA
PCB Layout PDF RevBRevBRevA
Data Pattern Generator
The Data Pattern Generator (DPG) is a bench-top instrument for driving vectors into high-speed digital-to-analog converters. The DPG connects to a USB on a PC and allows a user to download a vector from the PC into the internal memory of the DPG. Once downloaded, the vector can be played out to an attached evaluation board for a specific DAC at full speed. This allows for rapid evaluation of the DAC with both generic and custom-generated test data.
For more information on the DPG line of pattern generators and software:
评论(0)
发评论
下载排行榜
