ISL6622B pdf datasheet (Rectif
消耗积分:2 | 格式:rar | 大小:333 | 2009-02-07
分享资料个
The ISL6622B is a high frequency MOSFET driver designed
to drive upper and lower power N-Channel MOSFETs in a
synchronous rectified buck converter topology. The advanced
PWM protocol of ISL6622B is specifically designed to work
with Intersil VR11.1 controllers and combined with
N-Channel MOSFETs, form a complete core-voltage regulator
solution for advanced microprocessors. When ISL6622B
detects a PSI PWM protocol sent by an Intersil VR11.1
controller, it activates Diode Emulation (DE) operation;
otherwise, it operates in normal Continuous Conduction
Mode (CCM) PWM mode.
评论(0)
发评论
下载排行榜
