500MHz Rail-to-Rail Amplifiers
The 5962-0623501QPC, 5962-0623502QPC are fully DSCC SMD compliant parts and the SMD data sheets are available on the DSCC website
http://www.elecfans.com).
The 5962-0623501QPC is electrically equivalent to the
EL8102 and the 5962-0623502QPC is electrically equivalent
to the EL8103, reference these data sheets for additional
information. These parts are single rail-to-rail amplifiers with
a -3dB bandwidth of 500MHz and slew rate of 600V/μs.
Running off a very low 11mA supply current, the
5962-0623501QPC, 5962-0623502QPC also feature inputs
that go to 0.15V below the VS- rail.
The 5962-0623501QPC includes a fast-acting
disable/power-down circuit. With a 25ns disable and a 200ns
enable, the 5962-0623501QPC is ideal for multiplexing
applications.
The 5962-0623501QPC, 5962-0623502QPC are designed
for a number of general purpose video, communication,
instrumentation, and industrial applications. Both parts are available in 8 Ld SBDIP. All are specified for operation over the -55°C to +125°C temperature range.
