基于DC569B电池充电器的参考设计
消耗积分:2 | 格式:pdf | 大小:777.39KB | 2021-08-20
分享资料个
说明
  • DC569B, Demonstration Circuit is a single cell Li-Ion linear charger in a SOT-23. Charge rates as high as 600mA can be achieved due to the LTC4054 internal die temperature control loop that prevents excessive PCB heating under worst-case conditions. The user is provided with a control jumper to select between OFF/450mA/600mA charge rates. The reduced charge rate is suitable for USB applications. A charge LED illuminates while the charger is charging the battery
主要特色
  • Battery Type
    Lithium-Ion
  • Input Voltage
    4.25 to 10 V
  • Output Voltage
    4.2 V
  • Number of Battery Cells
    1
评论(0)
发评论
下载排行榜
