MAX9989, MAX9990 pdf datasheet
消耗积分:3 | 格式:rar | 大小:333 | 2009-02-21
1123127317
分享资料个
The MAX9989 and MAX9990 LO buffers provide the high output (+14dBm to +20dBm) necessary to drive the LO inputs of high-linearity passive mixers, while offering 40dB reverse isolation to prevent LO pulling. The MAX9989 is internally matched for the cellular/GSM bands, and the MAX9990 is matched for the DCS/PCS/UMTS bands.
The Typical Application Circuit provides a nominal +17dBm output power with ±1dB variation over supply, temperature, and input power. With two optional resistors, the output power can be precision set from +14dBm to +20dBm. The devices offer more than 35dB main driver output to PLL amp output isolation. Each device is offered in a 5mm x 5mm 20-pin thin QFN package with exposed paddle.
评论(0)
发评论
下载排行榜
