The Contek TA7678 is a monolithic integrated circuit designed for the VIF and SIF stage in B/W television receivers. The UTC TA7678 is used for forward AGC Type. FEATURE VIF STAGE *High gain wide brand IF amplifier 50dB at 45MHz *Gain reduction with excellent stability: 55dB at 45MHz *Excellent DG/DP and S/N characteristics SIF STAGE *Excellent limiter characteristics *Excellent AM Rejection *Large undistorted audio output voltage with quadrature detector
