研究了修理延迟的两个不同部件组成的冷贮备系统。假定工作寿命、延迟修理时间和修理时间均服从一般分布,利用马尔可夫更新过程知识和使用拉普拉斯变换(或拉普拉斯−司梯阶变换),讨论了系统的首次故障前时间、可用度和平均故障次数等可靠性指标,获得重要的结果。
关 键 词 延迟修理; 更新过程; 可靠性; 冷贮备系统
This paper considers a cold standby system consisting of two different units with t delay repair. Assuming that the working life, the delay repair time and the repair time are general distributions , some main reliability quantities, such as MTTFF, availability and average failure number, are analyzed by Markov renewal process and Laplace transform. Some important reliability results are obtained.
