可以通过 OpenAPI Generator,在给定 OpenAPI 规范(v2, v3)的情况下自动生成 API 客户端库、server stubs、文档以及配置。
目前支持以下语言/框架:
| Languages/Frameworks | |
| API clients | ActionScript, Ada, Apex, Bash, C# (.net 2.0, 3.5 or later), C++ (cpprest, Qt5, Tizen), Clojure, Dart, Elixir, Elm, Eiffel, Erlang, Go, Groovy, Haskell (http-client, Servant), Java (Jersey1.x, Jersey2.x, OkHttp, Retrofit1.x, Retrofit2.x, Feign, RestTemplate, RESTEasy, Vertx, Google API Client Library for Java, Rest-assured), Kotlin, Lua, Node.js (ES5, ES6, AngularJS with Google Closure Compiler annotations) Objective-C, Perl, PHP, PowerShell, Python, R, Ruby, Rust (rust, rust-server), Scala (akka, http4s, scalaz, swagger-async-httpclient), Swift (2.x, 3.x, 4.x), Typescript (AngularJS, Angular (2.x - 6.x), Aurelia, Fetch, Inversify, jQuery, Node) |
| Server stubs | Ada, C# (ASP.NET Core, NancyFx), C++ (Pistache, Restbed), Erlang, Go, Haskell (Servant), Java (MSF4J, Spring, Undertow, JAX-RS: CDI, CXF, Inflector, RestEasy, Play Framework, PKMST), Kotlin, PHP (Lumen, Slim, Silex, Symfony, Zend Expressive), Python (Flask), NodeJS, Ruby (Sinatra, Rails5), Rust (rust-server), Scala (Finch, Lagom, Scalatra) |
| API documentation generators | HTML, Confluence Wiki |
| Configuration files | Apache2 |
| Others | JMeter |
