INA128-HT,pdf (Precision Low Power Instrumentation Amplifier
消耗积分:5 | 格式:exe | 大小:1290 KB | 2011-02-06
分享资料个
The INA128 and INA129 are low power, general purpose instrumentation amplifiers offering excellent accuracy.
The versatile three operational amplifier design and small size make them ideal for a wide range of applications.
Current-feedback input circuitry provides wide bandwidth even at high gain.
A single external resistor sets any gain from 1 to 10,000. The INA128 provides an industry-standard gain
equation; the INA129 gain equation is compatible with the AD620.
The INA128/INA129 is laser trimmed for very low offset voltage (50 mV) and high common-mode rejection (93 dB
at G ≥ 100). It operates with power supplies as low as ±2.25 V, and quiescent current of 2 mA - typically. Internal
input protection can withstand up to ±40 V without damage.
The INA129 is available in 8-pin ceramic DIP and 8-pin ceramic surface-mount packages, specified for the –55°C
to 210°C temperature range. The INA128 is available in an 8-pin SO-8 surface-mount package, specified for the
–55°C to 175°C temperature range.
评论(0)
发评论
下载排行榜
