4.Arduino Nano的I2C屏蔽
The hardware hookup section basically explains the wiring connections required between the sensor and the Arduino Nano. Ensuring correct connections is a basic necessity while working on any system for the desired output. So, the requisite connections are as follows:
Only four connections are required: Vcc, Gnd, SCL and SDA pins. These are connected with the help of an I2C cable. These connections are demonstrated in the pictures above.
Lets start with the Arduino code now.
While using the sensor module with the Arduino, we include Wire.h
library. The Wire library contains the functions which facilitate the I2C communication between the sensor and the Arduino board.
The entire Arduino code is given in the below Code section for the convenience of the user.
In the Wire library, Wire.write()
and Wire.read()
are used to write the commands and read the sensor output. Serial.print()
and Serial.println()
are used to display the output of the sensor on the serial monitor of the Arduino IDE. The output of the sensor is shown in the picture above.
CPS120 has a variety of applications. It can be employed in portable and stationary barometers, altimeters etc. Pressure is an important parameter to determine the weather conditions and considering that this sensor can be installed at weather stations too. It can be incorporated in air control systems as well as vacuum systems.
