RT8488 pdf(High Voltage 6-CH LED Driver Controller)
消耗积分:5 | 格式:rar | 大小:385 KB | 2011-05-06
分享资料个
The RT8488 is a 6-CH LED driver controller that delivers
well matched LED current to each channel of LED string.
With external current sources, the number of LEDs per
string is only limited by the current source and the VIN/
VOUT conditions. The current mode PWM boost type
controller operates at a programmable switching frequency
of up to 1MHz, with a wide VIN range covering from 7V to
28V. The switch driver is designed to drive industrial grade
high power MOSFETs.
评论(0)
发评论
下载排行榜
