The MAX11634–MAX11637 are serial 12-bit analog-todigitalconverters (ADCs) with an internal reference andtrue differential track/hold. These devices feature on-chipFIFO, scan mode, internal clock mode, internal averaging,and AutoShutdown™. The maximum sampling rate is300ksps using an external clock. The MAX11636/MAX11637 have 8 input channels and the MAX11634/MAX11635 have 4 input channels. These four devicesoperate from either a +3V supply or a +5V supply, andcontain a 10MHz SPI™-/QSPI™-/MICROWIRE™-compatibleserial port.
