MAX16948双遥控天线LDO开关
消耗积分:0 | 格式:pdf | 大小:246 KB | 2012-01-04
分享资料个
Abstract: This application note helps system designers choose the correct external components for use with the MAX16948 dualremote antenna LDO/switch, thus ensuring that automobile-regulated phantom antenna supply and output-current-monitoring circuitrymeet performance objectives. An electronic calculator is provided that helps specify the critical external components for theMAX16948, thus reducing design time. The calculator also determines the device's analog output voltage, output current-limitthreshold, and output current-sensing accuracies. The calculator includes new automatic Step By Step feature that assists designerswith component choice. To use the new automatic feature, click on the Step By Step button relative to the desired section.
评论(0)
发评论
下载排行榜
