MAX15101,Low-Dropout Linear Regulator
消耗积分:0 | 格式:pdf | 大小:737 KB | 2012-01-17
分享资料个
The MAX15101 is a small, low-dropout linear regulatoroptimized for networking, datacom, and server applications.The regulator delivers up to 1A from a 1.7V to 5.5Vinput supply with output accuracy of Q1.6%. The outputis adjustable down to 0.6V with a guaranteed dropoutvoltage of less than 100mV at full load. The internalp-channel switch is protected with a foldback currentlimit and thermal shutdown.The MAX15101 features an external bypass input toreduce noise. This bypass input also serves as a softstartcontrol. An enable input and power-good output areincluded for power sequencecontrol.The MAX15101 is available in a 1.6mm x 2.7mm WLPpackage and is fully specified from the -40NC to +85NCoperating temperature range.
评论(0)
发评论
下载排行榜
