MC34152/MC33152/MC34152PG,pdf
消耗积分:10 | 格式:rar | 大小:333 | 2008-03-25
自我清欢
分享资料个
The MC34152/MC33152 are dual noninverting high speed drivers
specifically designed for applications that require low current digital
signals to drive large capacitive loads with high slew rates. These
devices feature low input current making them CMOS/LSTTL logic
compatible, input hysteresis for fast output switching that is
independent of input transition time, and two high current totem pole
outputs ideally suited for driving power MOSFETs. Also included is
an undervoltage lockout with hysteresis to prevent system erratic
operation at low supply voltages.
Typical applications include switching power supplies, dc−to−dc
converters, capacitor charge pump voltage doublers/inverters, and
motor controllers.
This device is available in dual−in−line and surface mount packages.
Features
• Pb−Free Packages are Available
• Two Independent Channels with 1.5 A Totem Pole Outputs
• Output Rise and Fall Times of 15 ns with 1000 pF Load
• CMOS/LSTTL Compatible Inputs with Hysteresis
• Undervoltage Lockout with Hysteresis
• Low Standby Current
• Efficient High Frequency Operation
• Enhanced System Performance with Common Switching Regulator
Control ICs
• NCV Prefix for Automotive and Other Applications Requiring Site
and Control Changes
评论(1)
发评论
dong12121 2019-04-16
0 回复 举报
看看工程要用 收起回复
下载排行榜
全部1条评论
