The TDA2616 and TDA2616Q are dual power amplifiers.
The TDA2616 is supplied in a 9-lead single-in-line (SIL9)
plastic power package (SOT131), while the TDA2616Q is
supplied in a 9-lead SIL-bent-to-DIL plastic power package
(SOT157). They have been especially designed for mains
fed applications, such as stereo radio and stereo TV.
· Requires very few external components
· No switch-on/switch-off clicks
· Input mute during switch-on and switch-off
· Low offset voltage between output and ground
· Excellent gain balance of both amplifiers
· Hi-fi in accordance with IEC 268 and DIN 45500
· Short-circuit proof and thermal protected
· Mute possibility.
