CD4528BC.pdf
消耗积分:5 | 格式:rar | 大小:122 | 2008-04-02
分享资料个
The CD4528BC is a dual monostable multivibrator. Each
device is retriggerable and resettable. Triggering can occur
from either the rising or falling edge of an input pulse,
resulting in an output pulse over a wide range of widths.
Pulse duration and accuracy are determined by external
timing components Rx and Cx.
Features
 Wide supply voltage range: 3.0V to 18V
 Separate reset available
 Quiescent current = 5.0 nA/package (typ.) at 5.0 VDC
 Diode protection on all inputs
 Triggerable from leading or trailing edge pulse
 Capable of driving two low-power TTL loads or one lowpower
Schottky TTL load over the rated temperature
range
评论(0)
发评论
下载排行榜
