The DS1080L is a low-jitter, crystal-based clock generatorwith an integrated phase-locked loop (PLL) to generatespread-spectrum clock outputs from 16MHz to134MHz. The device is pin-programmable to select theclock multiplier rate as well as the dither magnitude.The DS1080L has a spread-spectrum disable modeand a power-down mode to conserve power.
