78M6613快速入门指南
消耗积分:0 | 格式:pdf | 大小:582 KB | 2012-07-11
muobai
分享资料个
The 78M6613 PSU Firmware is a turnkey energy measurement solution optimized for use in AC power supply units (PSUs). At the sensor interface, the 78M6613 with PSU Firmware supports one voltage sense input one current sense input, and an optional input for an external thermistor voltage measurement. At the host interface, ready-to-use data is available over a low baud-rate serial interface for minimal cost of data isolation. Other key attributes of the PSU solution for the 78M6613 include:
评论(0)
发评论
下载排行榜
