高精度温度测量铂电阻温度探测器(PRTDs)和​​ADC
消耗积分:0 | 格式:pdf | 大小:331 KB | 2012-08-03
分享资料个
Abstract: Many modern industrial, medical, and commercial applications require temperature measurements in the extended temperature rangewith accuracies of ±0.3°C or better, performed with reasonable cost and often with low power consumption. This article explains how platinumresistance temperature detectors (PRTDs) can perform measurements over wide temperature ranges of -200°C to +850°C, with absolute accuracyand repeatability better than ±0.3°C, when used with modern processors capable of resolving nonlinear mathematical equation quickly and costeffectively. This article is the second installment of a series on PRTDs. For the first installment, please read application note 4875, "High-Accuracy Temperature Measurements Call for Platinum Resistance Temperature Detectors (PRTDs) and Precision Delta-Sigma ADCs."
评论(1)
发评论
qindaodz 2013-05-27
0 回复 举报
谢谢分享! 收起回复
下载排行榜
全部1条评论
