MAX5386, MAX5388,pdf datasheet
消耗积分:5 | 格式:rar | 大小:333 | 2009-05-29
吴湛
分享资料个
The MAX5386/MAX5388 dual, 256-tap, volatile low-voltage
linear taper digital potentiometers offer three end-to-end
resistance values of 10kI, 50kI, and 100kI. Operating
from a single +2.6V to +5.5V power supply these devices
provide a low 35ppm/NC end-to-end temperature
coefficient. The devices feature an SPIK interface.
The small package size, low supply voltage, low supply
current, and automotive temperature range of the
MAX5386/MAX5388 make the devices uniquely suitable
for the portable consumer market, battery backup industrial
applications, and the automotive market.
The MAX5386 includes two digital potentiometers in a
voltage-divider configuration. The MAX5388 includes
one digital potentiometer in a voltage-divider configuration
and one digital potentiometer in a variable-resistor
configuration. The MAX5386/MAX5388 are specified
over an extended -40NC to +125NC temperature range
and are available in 16-pin, 3mm x 3mm TQFN or 10-pin,
3mm x 5mm FMAXM packages, respectively.
Applications
Low-Voltage Battery Applications
Portable Electronics
Mechanical Potentiometer Replacement
Offset and Gain Control
Adjustable Voltage References/Linear Regulators
Automotive Electronics
评论(0)
发评论
下载排行榜
