The MAX3747A/MAX3747B multirate limiting amplifiersfunction as data quantizers for OC-3 through OC-48 synchronousoptical network (SONET), Fibre-Channel, andGigabit Ethernet optical receivers. They are pin-for-pincompatible with the SY88993V from MicrelSemiconductor, Inc. The amplifiers accept a wide rangeof input voltages and provide constant-level, currentmodelogic (CML) output voltages with controlled edgespeeds. The MAX3747A/MAX3747B output voltages are800mVP-P. The MAX3747B has enhanced LOS operationunder overload conditions.
