MAX5395数据资料
消耗积分:0 | 格式:pdf | 大小:1.27 MB | 2012-11-08
分享资料个
The MAX5395 single, 256-tap volatile, low-voltagelinear taper digital potentiometer offers three end-toendresistance values of 10kΩ, 50kΩ, and 100kΩ.Potentiometer terminals are independent of supply forvoltages up to 5.25V with single-supply operation from1.7V to 5.5V (charge pump enabled). User-controlledshutdown modes allow the H, W, or L terminal to beopened with the wiper position set to zero-code, midcode,full-code, or the value contained in the wiperregister. Ultra-low-quiescent supply current (< 1μA) canbe achieved for supply voltages between 2.6V and 5.5Vby disabling the internal charge pump and not allowingpotentiometer terminals to exceed the supply voltage bymore than 0.3V. The MAX5395 provides a low 50ppm/°Cend-to-end temperature coefficient and features an I2Cserial interface.
评论(1)
发评论
XtTx 2014-07-21
0 回复 举报
感谢楼楼分享,有要找资料,谢谢楼楼 收起回复
下载排行榜
全部1条评论
