ad736 pdf
消耗积分:10 | 格式:rar | 大小:333 | 2008-04-14
分享资料个
The AD736 is a low power, precision, monolithic true
rms-to-dc converter. It is laser trimmed to provide a maximum
error of ±0.3 mV ±0.3% of reading with sine-wave inputs. Fur-
thermore, it maintains high accuracy while measuring a wide
range of input waveforms, including variable duty cycle pulses
and triac (phase) controlled sine waves. The low cost and small
physical size of this converter make it suitable for upgrading the
performance of non-rms “precision rectifiers” in many applica-
tions. Compared to these circuits, the AD736 offers higher ac-
curacy at equal or lower cost.
The AD736 can compute the rms value of both ac and dc input
voltages. It can also be operated ac coupled by adding one ex-
ternal capacitor. In this mode, the AD736 can resolve input sig-
nal levels of 100 µV rms or less, despite variations in
temperature or supply voltage. High accuracy is also maintained
for input waveforms with crest factors of 1 to 3. In addition,
crest factors as high as 5 can be measured (while introducing
only 2.5% additional error) at the 200 mV full-scale input level.
The AD736 has its own output buffer amplifier, thereby provid-
ing a great deal of design flexibility. Requiring only 200 µA of
power supply current, the AD736 is optimized for use in por-
table multimeters and other battery powered applications.
The AD736 allows the choice of two signal input terminals: a
high impedance (1012
 Ω) FET input which will directly interface
with high Z input attenuators and a low impedance (8 kΩ) inputwhich allows the measurement of 300 mV input levels, while
operating from the minimum power supply voltage of +2.8 V,
–3.2 V. The two inputs may be used either singly or differentially.
The AD736 achieves a 1% of reading error bandwidth exceeding
10 kHz for input amplitudes from 20 mV rms to 200 mV rms
while consuming only 1 mW.
The AD736 is available in four performance grades. The
AD736J and AD736K grades are rated over the commercial tem-
perature range of 0°C to +70°C. The AD736A and AD736B
grades are rated over the industrial temperature range of –40°C
to +85°C.
The AD736 is available in three low-cost, 8-pin packages: plastic
mini-DIP, plastic SO and hermetic cerdip.
评论(0)
发评论
下载排行榜
