提出了一种以多个DSP 和FPGA 为核心器件构成的视频检测与跟踪装置设计方案。 该视频检测与跟踪装置,可利用电视图像或红外图像两个波段跟踪,采用形心跟踪和相关匹配跟踪两种模式来提高跟踪的置信,同时采用了去移动阴影算法和线性拟和外推预测方法去跟踪目标。 关键词:DSP FPGA 图像跟踪 双模 Abstract: The design and implementation of a video tracker based on the multi high speed DSP and the FPGA is presented in this paper. Double-wave-bands about TV image and infra-red image are available in this video tracker. In order to improve the confidence, this device adopts the mass centroid tracking algorithm and the correlation matching algorithm. The remove moving shadow algorithm and linear fitting prediction approach are also used to track targets. Key words: DSP FPGA image tracking dual-mode
