MAX531-MAX539
消耗积分:2 | 格式:pdf | 大小:207KB | 2014-08-19
紫气zz
分享资料个
The MAX531/MAX538/MAX539 are low-power, voltageoutput,12-bit digital-to-analog converters (DACs) specified for single +5V power-supply operation。 The MAX531 can also be operated with ±5V supplies。 The MAX538/MAX539 draw only 140µA, and the MAX531 (with internal reference) draws only 260µA。 The MAX538/MAX539 come in 8-pin DIP and SO packages, while the MAX531 comes in 14-pin DIP and SO packages。 All parts have been trimmed for offset voltage,gain, and linearity, so no further adjustment is necessary。
评论(0)
发评论
下载排行榜
