ROK 101 008 is a short-range module for implementing Bluetooth functionality into various electronic devices。The module consists of three major parts;a baseband controller,a flash memory,and a radio that operates in the globally available 2.4–2.5 GHz free ISM band。 Both data and voice transmission is supported by the module。Communication between the module and the host controller is carried out via UART and PCM interface。ROK 101 008, which is compliant with Bluetooth version 1.0B and critical errata,is a Class 2 Bluetooth Module (0 dBm) and is type-approved。
