集成化涡街传感器
消耗积分:3 | 格式:rar | 大小:326 | 2009-07-14
陈文博
分享资料个
通过对带温压补偿的集成化涡街传感器构造原理、性能特点等方面的分析, 阐述了一种流量计量新产品的构造思路, 在涡街传感器中集成压力和温度传感器, 让它们三者合为一体。这样, 即降低了涡街的误差, 也减少了分离式补偿的复杂性。
关键词: 集成传感器; 物理结构; 补偿公式; 性能特点
Key words: in tegrated f ran sducer; physical st roctu re; con ipeu sat ion fo rm u la; characterist ic featu res Abstract: O n the basis of analysis of the m echam ism and characterist ic featu res of in tegrated vo r2 tex f low t rou sducers w ith temperatu reöp ressu re compen sat ion s, a new type of f low m easu re m en t t ran sducer is p resen ted,w h ich in tegrates vo rtex f low t ran sducer, temperatu re t ran sducer and p res2 su re t ran sducer together and thu s decreases the vo rtex erro r and the comp lex ity of the standalene compen sat ion s.
评论(0)
发评论
下载排行榜
