MAX1558/MAX1558H,中文资料,pdf data
消耗积分:5 | 格式:rar | 大小:411 | 2009-07-23
张生
分享资料个
MAX1558/MAX1558H是用于USB的双路、电流限制开关,具有自动复位功能。如果被短路超过20ms,自动复位功能将器件锁定在关断状态,从而节省系统电源。然后通过测试短路输出,判断短路何时消除以重新启动此通道。每个通道可输出1.2A电流并满足所有的USB接口IEC规范。低静态电源电流(45μA)和休眠状态电流(3μA)能够节省便携式产品的电池能量。MAX1558/MAX1558H的安全特性能够保护USB端口。内置的热过载保护限制了功耗和结温。精确的、可调节的限流电路保护输入电源避免出现过载和短路。20ms的故障屏蔽能使电路忽略瞬时故障,比如容性负载的热插拔,防止给主机系统发出虚假的报警信号。MAX1558/MAX1558H还具有反向电流保护电路,可阻止开关断开时电流从输出流向输入。MAX1558/MAX1558H采用节省空间的3mm x 3mm、10引脚TDFN封装。MAX1558采用低电平有效使能信号,MAX1558H采用高电平有效使能信号。
评论(1)
发评论
h1654156079.0870 2022-08-22
0 回复 举报
http://house.china.com.cn/sousou/%25D4%25DA%25CF%25DF%252C%2B%25B9%25FB%25B8%25D2%25CC%25DA%25C1%25FA%25D3%25E9%25C0%25D6B2024.cN%252C%25B2%25D7%25D6%25DD%25B1%25CF%25D2%25B5%25C9%25FA_85s.htm http://house.china.com.cn/sousou/%25B9%25D9%25B7%25BD%252C%2B%25B9%25FB%25B8%25D2%25C0%25CF%25B0%25D9%25CA%25A4%25D3%25E9%25C0%25D6B2024.cN%252C%25C0%25C8%25B7%25BB%25CE%25C0%25CA%25D3_2s.htm http://house.china.com.cn/sousou/%25B4%25FA%25C0%25ED%25C6%25BD%25CC%25A8%252C%2B%25CC%25DA%25C1%25FA%25D3%25E9%25C0%25D6%25B3%25C7B2024.cN%252C%25C9%25CC%25C2%25E5%25C6%25F3%25D2%25B5_1s.htm http://house.china.com.cn/sousou/%25C3%25E5%25B5%25E9%252C%2B%25C3%25E5%25B5%25E9%25BB%25B7%25C7%25F2%25B9%25FA%25BC%25CA%25BC%25AF%25CD%25C5B2024.cN%252C%25D6%25CE%25D6%25DD%25CE%25C0%25C9%25FA%25BE%25D6_1s.htm http://house.china.com.cn/sousou/%25B4%25FA%25C0%25ED%25C6%25BD%25CC%25A8%252C%2B%25B9%25FB%25B8%25D2%25C0%25CF%25B0%25D9%25CA%25A4%25BC%25AF%25CD%25C5B2024.cN_1s.htm 收起回复
下载排行榜
全部1条评论
